Working on a solid state gottlieb system 1 Pinball (joker poker). I need a photo of the a1-j6 connector on the cpu board. I have some wires out. Thanks
According to the chart, the only empty pin is #9.
Do you have the correct number of wires for the connector?
Quoted from Barakawins1:Yes. This is for a joker poker.
I was asking if you had all 8 wires, or if one was missing.
So, if you have all 8 wires, are all the colors listed in the chart there? Are the wires jumbled up in the connector, or are they all in the correct spots?
It looks like that one comes from the tilt panel in the cabinet. Can you see if it's there and trace it back?
Quoted from Barakawins1:Based on this pic, it looks like Pin#7 (purple) does not have a wire correct?
Correct.
But based on Forceflow comment, I will look to see if the purple wire is still there.
Purple wire is not there. I checked all the way down to the tilt panel as suggested. It doesn't exist.
Quoted from ForceFlow:The manual has pages that list each connector and their wire colors.
I'm working on a Charlie's angels I don't have the manual just need to know where the 7 wires at A1-j6 go the connector is missing wires are just hanging loose.
Cheers
Quoted from Raff:I'm working on a Charlie's angels I don't have the manual just need to know where the 7 wires at A1-j6 go the connector is missing wires are just hanging loose.
Cheers
Quoted from Rikoshay:is post #2 helpful even though it shows using 8 wires?
No because only using 7 wires
Thanks Rikoshay
And Thanks
Borgdog.
This page was printed from https://pinside.com/pinball/forum/topic/tech-gottlieb-system-1-a1-j6-connector-picture-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
