(Topic ID: 21928)
Solved! Tech- Gladiators game freezes after calm before storm round ends ideas
By Greg2608
11 years ago
  • 14 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by Impzilla
#1 11 years ago
While playing gladiators when i get to calm before the storm round it starts and plays till
the round ends then the ball locks and freezes game with the mega bonus being displayed on display sound continues to play but game play stops
anyone have any ideas
thanks for any help provided
Greg
#2 11 years ago
Not familiar with the game so I can't be real specific, but I would reseat all ribbon cables and check the power supply voltages.
Also, if I understand correctly right after a ball is locked the game locks up? At that point would it normally kick the ball out?
If so I would test the switch and solenoid in diagnostics and make sure they test ok and do not lock the game up.
#3 11 years ago
Quoted from terryb:
Thanks terry yes and up to that exact point it does release ball in all other cases. Just when it finishes that round. Ill go through all cables in test mode the solenoid and switches all work properly.
#4 11 years ago
After the lockup, can you still use the flippers? If you play with the glass off, can you score by manually pressing targets etc?
I haven't performed the ground upgrades on my Stargate yet, but faulty grounds can cause all kinds of weird issues.
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_3#Ground_Upgrades
Any time a computer acts funny, I look at the supply voltage.
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_3#Low_Voltage
#5 11 years ago
And I have to correct my self it is in the beast challenge round that it locks up
and yes flippers still work pop bumpers fire just triggering them by hand but nothing changes on the dmd it shows mega bonus and value
#6 11 years ago
Hey on your Gladiators does your shaker motor work like other games? Only ask because mine shakes so hard on concrete floors that it will move it around. Do you know if it has a jumper to decrease its power.
#7 11 years ago
I ha
Quoted from marlboroa:Do you know if it has a jumper to decrease its power.
not sure was going to look into it i unplugged mine made the dog go nuts upstairs everytime it went off lol
#8 11 years ago
re checked all ribbon connections still freezes gameplay when beast challenge round is up. Flippers still work and all pop bumpers fire but display reads mega bonus and the value ....
any suggestions would be great
thanks
#9 11 years ago
Have you checked your power supply voltages yet? I don't have schematics, but you want to check the 5 Volts in particular on the board with the MPU.
Also, if you let the game sit does it search for the ball?
#10 11 years ago
Quoted from Greg2608:
While playing Gladiators when i get to calm before the storm round it starts and plays till
Greg
With symptoms like this, I always consider game ROMs and RAM suspect. Problems like this are tough to track down. I fixed a Shaq that would lose sound every time multiball started. It was one of the 5116/6116 RAMs on the MPU.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://webpages.charter.net/chibler/Pinball.htm
#11 11 years ago
I also think you have to look extra carefully at the lamps and make sure that all work properly in single lamp test mode and you have no ghosting of other lamps. If a lamp is wired incorrectly or is shorted it can cause problems with the switch matrix as well because of the shared strobes. Sounds like you're in a mode where a light is on and you hit the spinner and the system becomes confused. As they say, wire one lamp backwards on a Sys3 and you "unleash hell." (OK, maybe a bit of overstatement but seems appropriate for the game...)
viperrwk
#12 11 years ago
Quoted from rancegt:
Ill have to check power supply tonight hoping to at least but I do know the game does not
search for ball. i let it run for awhile one time to see and sound continued to play and i could activate flippers and pop bumpers but nothing else would work
I will also run the lamp test that was suggested to
thank you everyone for advise and help
1 year later
#13 10 years ago
I ended up replacing the U8-G on the display board and solved the issue.
6 years later
#14 3 years ago
I know this is a super old thread but I will post my fix for the exact same issue.
Per my board repair specialist:
Take the CPU board out of the game and place on a flat surface that is not metal. Gently pry the RAM chip U3 (5164) out of its chip socket, leave the chip out for 30 seconds and then re-insert the chip being careful not to bend any legs under the chip. This will effectively wipe any stored memory.
Get into settings, perform a factory reset. Don’t go further without doing the factory reset.
Following these steps resolved my issue.
Not saying the OP technique doesn't apply too but the above steps resolved my issue without parts and may be a good first step before replacing U8-G.
$ 1.00
Pinball Alley
2,450 (OBO)
Centerport, NY
$ 3.00
Tools
Nezzy's Pinball Prints
2,699
Wichita, KS
This page was printed from https://pinside.com/pinball/forum/topic/tech-gladiators-game-freezes-after-calm-before-storm-round-ends-ideas and we tried optimising it for printing. Some page elements may have been deliberately hidden.
