(Topic ID: 82000)
Tech: Gameplan Sharp Shooter 2 will not go on 3 ball
By Gundam_Pilot_
10 years ago
#1 10 years ago
Hey guys. I have a gameplan Sharp Shooter 2 that I am working on. Game works well. Its on 5 ball right now and I chose the correct dip switch to change it to 3 ball but it is not doing anything. Any suggestions?
#2 10 years ago
Did you change it with the game off? Are you sure it was the correct dip switch? Need to start with the easily overlooked stuff first.
Jason
#3 10 years ago
Yah the game was off, I have cycled it a few times since i switched it. And yes I am sure its the correct one. If i memory serves me correctly, the manual says its dip 28 to "off" for 3 ball. I am not sure if the dip is bad, but I plan on testing it when I get home.
#4 10 years ago
I had a similar issue with a Classic Stern game that I recently restored. It was stuck on 5-ball mode.
Try rocking that dip switch back and forth a few times to make sure it's clean.
I ended up replacing the dip bank and that solved my problem.
#5 10 years ago
Yeah - definitely check that DIP switch as it could be stuck on not giving you three ball. It's also possible (though unlikely) you could have an issue with the 74154 at U14 as the switches are tied to it, but if this were the case you'd be seeing other problems as well.
Don't forget to check the diode that goes with that switch as well.
viperrwk
#6 10 years ago
Yah I will figure it out tonight. I may just have to remove the leg for the time being just to simulate an "Off" state.
$ 98.99
PinballReplacementParts
$ 12.00
$ 16.50
Magazines/books
Pinball Magazine
This page was printed from https://pinside.com/pinball/forum/topic/tech-gameplan-sharp-shooter-2-will-not-go-on-3-ball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
