I've looked in the Gameplan guide thread and can't find the issue I'm having. It's not a huge deal as it's been this way for almost 2 years now, but would like to get it fixed. There is absolutely no battery damage. Super clean board running a 1.5F supercap. The game is Cyclopes if that matters.
Here's the issue:
Game off. Turn game on with switch and most times (7/10) just the GI lights come on and then nothing. Turn off and back on and game boots up and plays fine. Sometimes (1/10) you might have to turn off and on again for a second time. When it boots up it plays fine, no issues whatsoever.
I do get all 6 flashes on the MPU when it does boot. When it doesn't boot. Nothing. I do notice that when I turn the game on and I don't get a quick flicker (usually of a 5) in the 10s score display it's not going to boot. If I turn it on and see the 5 flicker in the 10s digit of the display, I'm golden.
If the game turns on the first try, after it's been on and played previously, it retains the previous game scores. If it doesn't boot on the first try you get garbage numbers. Typically like 910910 in all 4 positions, and the high score to date is like 9910300.
I've replaced the boot up section transistors, Z80 and PIA thinking that was the issue and no change. Now I'm thinking it might be the 6810 RAM, because it displays garbage when it does boot up. But I would think it would only do a partial boot up sequence because it checks the RAM in order to pass the 3rd flash.
Any ideas what the issue(s) may be? It's either nothing or full boot at power up. When it boots it plays perfectly fine.
