I'm having a problem with the boiler door on my Gottlieb Freddy. The boiler door is working sporadically throughout the course of a game. It basically starts going up and down at various times, and it does not seem to be caused by any one particular switch on the playfield. Every other switch & lamp/flasher appears to be working correctly during gameplay except for the Boiler Door which is not continually going up & down when it is supposed to.
One problem I was having prior to this was that the 2 flasher bulbs that light inside Freddy's head were staying locked on, so I removed the bulbs & disconnected the connector for them under the playfield. After this, I double-checked all fuses, removing each fuse & testing it to make sure that they were all still good.
The machine had a new Rottendog driver board installed after this incident happened.
I have already put the game into "Self Test" mode & gone through each test individually (Lamp/Flasher Test, Switch Test, Switch Matrix Test) to make sure that only 1 switch and/or 1 lamp/flasher is activated for each individual test.
The Boiler Door's switches & motor underneath the playfield work correctly in test mode. I even adjusted both switches actuators to make sure that the switches are being contacted by the motor. Also, the optos on the Boiler Door entrance work correctly in test mode & are activated correctly during gameplay.
Has anybody ever had a problem similar to this?
Can anybody tell me what I should try next?
Thanks for your help!
