I'll be first to admit I have no clue when I comes to PCB stuff (different caps/resistors/transistors/etc), but soldering and board repair is something I can do no problem; however, I need someone who knows what they're doing to help me out with this .
I referenced the manual (this is for a WCS94 restore I'm doing), and have already replaced the various TIP102 and 2N5401 transistors that were missing, but when I went to compare the resistors I had to stop.
I need to install the R92 and R93 resistors, and per the manual ordered a 2.7Kohm, 1/4W, 5% for R92 and a 68ohm, 1/4w, 5% for R93; but the new pieces don't match (visually) the older resistors. I tested the resistors with a meter and the 68ohm (R93) on both the old and replacement resistors tested at 68ohm, but the R92 replacements test at 2.7kohm (from the pic below, the packaging says both 2.7Kohm and 2.4Kohm on it) and the originals on the board are showing ~2.2kohm. I highlighted the manual for the boards resistors (and also highlighted a comparing resistor already on the board for visual reference)
Are these the correct resistors for my board or no? I'm just weirded out when parts don't match and don't know if the replacement parts I ordered are the correct ones (especially if newer resistors are smaller, different color, etc).
Sorry for the novel of a post (figured more info the better).
Thanks guys!
