New! Dark mode!
(Topic ID: 182652)
TECH: DE SW Left Flipper Showing ON in Switch Test?
By RDReynolds
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by RDReynolds
#1 3 years ago
Have been doing some work on my DE SW and it plays fine save for a couple weird things. I'm having an issue where my left flipper works ok in game (I hit the switch, it flips), but it's showing the switch is ON in the diagnostics. I think that's leading to a few issues in game wherein it thinks I am looking for a status update? Any idea what could be going on here?
#2 3 years ago
Well, the obvious first step would be to check the flipper switch and button, and make sure everything is kosher there.
#3 3 years ago
Yep, those appear fine. And if I hit the button, it flips. However if you go into a switch test, it never registers. It does say it is active in the active switch test though, so I think it believes it is on when it should be off from a software perspective...does that make any sense?
Example, when a tri-ball is starting it begins the animation (Imperial troopers prepping to fire) then goes into a status display before it finishes (Death Star fires)...
#4 3 years ago
Bumping this one as I cannot solve it. I literally disconnected the switch and it is still showing as being on in active switch test?
#5 3 years ago
Is it the flipper button switch or maybe the flipper end of stroke switch that is showing in the test?
#6 3 years ago
It says "left flipper" in the active switch test. I literally changed the physical switches themselves (moved the left one to the right and the right one to the left) and the problem still persists.
#7 3 years ago
Quoted from RDReynolds:
Yes but just because it says "left flipper" doesn't mean it refers to the left flipper actuating switch (flipper button switch). It could simply mean the "left flipper assembly" - I would be checking the EOS.
#8 3 years ago
Quoted from Homepin:
I don't believe that DE had EOS until JP. The flipper switch on my machine looks like this:
http://www.marcospecialties.com/pinball-parts/180-5048-01
I did switch the left switch to the right and the right switch to the left. The issue remained. So I am really scratching my head here.
Thanks again for your help!
#9 3 years ago
Could be a bad transistor Q7 on the flipperboard.
Does "left flipper" disappear when CN1 on the flipperboard is unplugged ?
#10 3 years ago
Yes, it does. What's interesting is that the light on the flipper board does flash when I hit the left flipper switch...the flipper also works.
#11 3 years ago
Yes, very interesting. I can watch that for hours.
The logic on flipperboard splits into a drive for the switch-matrix and a drive for the coil with High+Low power.
If for example the transistor for switch-matrix is shorted, the flipper and LED do still work.
#12 3 years ago
Quoted from zaza:
So thinking replace the transistor at Q7 then?
#13 3 years ago
It is most likely Q7 but maybe you can measure first for a short between CN1-5 and CN1-4 ( e to c of Q7)
You can compare with Q5 which is for switch "right flipper".
#14 3 years ago
Was able to swap out my friend's flipper board and sure enough the problem goes away. So it's definitely an issue with the board itself. Thanks to everyone for their help!
$ 27.00
$ 50.00
4,200 (OBO)
Saukville, WI
Arcade Upkeep
Metal-Mods
$ 9.99
