The recent production run from ColorDMD (Getaway) has a manufacturer error. if you're good with a meter, i can give you some ideas.
With the game powered on and your DMD set to DC volts, check for 3.3 volts at R2 (either side) and U2 pin 7 (these are right by the power .156" molex male connector.) I have attached a picture that shows these points (blue wire.) If there is a power problem, none of the three LEDs on the colordmd board will be "on."
If you get 3.3 volts at R2 and don't get 3.3 volts at U2 pin7, the via at R2 is most likely the problem. Randy from Colordmd says that re-soldering the R2 via often is all that is required.
I put a wire (blue wire in the picture) between these two points. I ran the wire because the colordmd worked fine for a few days, and then crapped out. I figured there was a problem that could be re-occurring, so the wire made the fix more permanent (in my eye at least.) It's probably overkill though.
Another note... the Aux and Pwr connectors are parallel connectors. Meaning you can attach the power cable to either connector. Once the colordmd is receiving proper power, the three tiny board LEDs will light up upon power on.
To add more detail... the chips on the colordmd board use 3.3 volts DC as power. Obviously wpc games don't supply that voltage. so the U1 chip takes 12 volts in at U1 pin 7, and converts it to 3.3 volts out at U1 pin 8. It goes through a choke L1 and resistor R1, then off the U2 pin 7. basically U1 is a small voltage regulator.
