(Topic ID: 307588)
TECH: CFTBL Won't Start
By lowga
2 years ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by fschlau
#1 2 years ago
TECH: We decided to replace the last stock board in our CFTBL with a brand new Rottendog A12697-1 MPU. We also replaced the back-up batteries, and did a factory reset on the game. Fired it back up, and now the game will not start. It's set up for free play, and nothing obvious is wrong. Game seems otherwise normal...but the start button doesn't light, and pressing it has no effect. Tried manually adding credits to the game (just in case.) No joy.
I'm not even sure how to begin troubleshooting this problem. Checked all the connectors and reseated them again. Still no job. Any suggestions?
Les & Abby Rayburn
Maylene, AL
#2 2 years ago
What does it actually do right now? Are you in attract mode? You mentioned setting it to free play. Can you get into the service menu?
Have you checked continuity of your start button back to the mpu? Or even to the cabinet board.
#3 2 years ago
You have 3 balls installed in the game, and are all the ball trough switches working?
#4 2 years ago
Need to go into Switch Test mode and see if the Start Button is actually being detected when pushed.
#5 2 years ago
The machine is in attract mode. The start switch does not light up (it did previously). In Switch Test mode, the start switch is not detected when pressed. I have a multimeter and can trace continuity but I'm not sure of the best way to accomplish this. Should I unplug the connector that holds these wires, and measure from the connector back to the button?
I can get into the service menu. Anything else I should check?
Thanks for all the assistance.
#6 2 years ago
Any connectors plugged in one pin off at the bottom of the MPU board?
#7 2 years ago
Take a picture of the bottom of the mpu and also the wiring for the start button inside the front of the cabinet
#8 2 years ago
Quoted from lowga:
Pics would be good. Did you replace the MPU due to corrosion? Unplug the connector and do the continuity check first. If you don't have it to there then go backwards towards the cabinet board. You could simply have some corrosion/buildup on that connector pins too. You may need to replace that connector. Anyways continuity first then go from there.
1 month later
#9 2 years ago
The problem turned out to be a connector on another board that lead from a "cabinet switch" that had become disconnected. Once reconnected, the game started right up.
We played the game a few times, and then had to go into another room to do some work. We left the machine on, planning to return to play more games later. A few hours later, we heard three loud "knocks" from the gameroom, similar to the sound of the knocker on a pinball machine. I went in to investigate, and finding nothing amiss decided to play a quick game on CFTBL.
The game will start, but now the flippers don't work at all. Back to the troubleshooting drawing board....
6 months later
#10 1 year ago
Quoted from lowga:
Check fuse F116, 12V
$ 9.95
$ 45.95
Mitchell Lighting
$ 150.00
$ 259.99
$ 27.95
$ 69.99
€ 99.00
Lighting - Under Cabinet
Watssapen shop
€ 25.00
PPmods
$ 280.00
Avid Creations Wireforms
7,500
Matthews, NC
YouBentMyWookie
$ 49.99
€ 24.00
$ 549.00
Juz PINBALL Mods
Metal-Mods
PinSound
West Chicago, IL
$ 250.00
Professor Pinball
$ 5.00
$ 29.95
Mitchell Lighting
8,000
Portland, ME
7,800
Anaheim, CA
$ 1,059.00
$ 329.99
€ 24.50
Pin-Decals
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/tech-cftbl-won-t-start and we tried optimising it for printing. Some page elements may have been deliberately hidden.
