I can't figure this out.
My Centaur is NOT making the launch sound each time a ball (ORB) is released, but does sound off occasionally.
I am pretty certain it should make the sound every single time.
On mine, the lights go out just before the ORB release (which is normal), but only sometimes do I hear the launch sound.
I don't know if there is a switch or relay that triggers the sound or what causes the sound.
All other sound effects seem normal and OK and as I said sometimes it makes the sound. All ORBS launch out as expected.
As a side note, I just replaced the power module board with a repro from K's Arcade. The reason was that all of the lights were randomly powering on and off and with the new board the game seems to work fine.
I wouldn't think that new power module board should have any bearing on the intermittent ORB launch sound issue, but thought I should mention it just in case.
Any thoughts or ideas appreciated.
Jeff
