Little history and then current status as I know a number of people have struggled with the long opto.
History - My game was giving me a number of ground row issues. The problem ended up being in the opto board up in the head. The board was repaired and tested out in another game and all is working well. When I placed it in my game all my issues were solved, but I was having a "load magnet error".
Now - I ordered new long distance optos and replaced both transmitter & receiver. I tested the opto's in switch test under the playfield and they were communicating with each other and I was able to get them a distance apart and they still worked. I mounted them in the game and was able to run the magnet test and all went well and the credit dot disappeared. Once I put all the parts back together and fired up the game I was getting "load magnet error" again. When I removed all the parts to get down to the opto's they started working again. I decided to put the parts on one by one with the game on so that I could test the switch after each part to try and determine if one was causing the issue. All was going well and as I tightened a nut on the plastic above the receiver (not the one on the gate) the opto's stopped working. I stripped all the parts off again and undid the opto's to try them under the playfield again. When I did this I can't get them to talk to each other now. I'm thinking I've got a wire issue between the opto and the board that they plug into or an issue with that board. I used a camera and it looks like the transmitter is lit.
Is there something that could cause the opto's to stop working (take them out)?
Welcome to any and all suggestions.
