Quoted from pinster68:I have an issue where sometimes (usually during a great game) a ball on the lower playfield of Black Hole drains, but doesn't make it past the first solenoid-driven gate to the up-kicker, and then the game just waits ... no ball search, and I'm stuck until I either power cycle the game, or manually move the ball out.
I've cleaned and adjusted the pathway and the gate mech, and leveled the pin repeatedly, but to no avail.
I recall skimming past a post some time back on this issue, and recall there being some guidance, but may have been on the go and didn't bookmark it.
Any assistance appreciated.
Brian
Sounds like the switch TO the lower PF works, and you are ALWAYS allowed to use the lower flippers.
This used to work fine 100% of the time, but now it doesn't?
Sounds like it's an intermittent problem?
Often intermittent = vibration = wires or connections. Any chance there's a broken/loose wire hiding in the mix?
I had this issue, but for me it was the "gate wire" not being the right length iirc. I had to get an original one, and I asked Cliffy to build me a new one from a length of wire, using an original as his guide. Of course he made the new a perfect copy. I had no problems after that. The issue was the little part that sticks out to push the ball, wasn't getting enough wire on the ball to move it. When I moved it in and out enough times, it became clear to me. I also had two Black Holes in the garage at the time, so I could compare and contrast -- that always makes diagnostics quicker.
I presume in your case, this is a situation where things all worked FINE before this issue, so you likely have the correct length of wire in there, yeah?
I resolved all of this visually by experimentation with the top PF up vertical, and starting a game by hand, by manipulating the start switches with a game "on" with no balls in the machine...
-mof
