I've noticed that my 12v increases (by hearing my backbox motor) when flickering stops. Kinda reverse logic, but I notice that the motor gets faster (increased power/RPM) and that lights become solid at same time. I played with the posts on the 6v lamps bridge rectifier last night and noticed that the flickering became less often (~5 to 10% of the time on).
I also checked the F5 fuse (controlled lamps) and it seems fine.
Disconnected - Controlled lamps off
Connected - Controlled lamps on
However - Somehow, there is continuity even when disconnected (Controlled lamps off). This is REALLY confusing, since there can't be continuity, if the power isn't going through, right????
I had the BH on for most of the day, and about 2 hours ago, I heard a noise from the BH. I walked over to check the backbox motor & lights (to check for variations that's been happening) and all the controlled lamps are out #UGH#.
I turned off the power, and now it doesn't boot. GI comes on, and that's it
I'm hoping that something in the power supply died, and now, it'll be easier to diagnose.
