Finally got around to working on my SF. The game had heavy acid damage on the CPU when I bought it so I purchased a NOS replacement board. I installed the board and after cleaning and reassembling the playfield played a few games. There were no issues until the game locked up about 15 minutes in. A reboot at this point shows 8 flashes on the board instead of 9. The 9th flash: "verifies operation of the Phase A switched ill. voltage. Note: F4 fuse on the power module provides the phase A signal to the control board. (U1, 6803) (U11, 4011) (U12, 14584)". The F4 fuse is correct according to the manual. Once it cools off you get the normal 9 flashes and it plays fine until 15 minutes or so goes by. Then it locks up again. What should I be looking at?
Steve
