New! Dark mode!
(Topic ID: 244441)
Tech: Bally Fathom - star roll over switches not scoring
By Barakawins1
1 year ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Quench
#1 1 year ago
I'm working on Fathom. there are several star roll over switches on this game. There are two that don't want to trigger during game play when the ball rolls over.
One is at the upper right ball lock and the other is at the middle right ball lock. In switch test manually they trigger fine. However, during game play I can press down
on the switches and they do nothing. Could this be the capacitors across the leaf switches? Anyone have this happen where the star roll overs aren't scoring? I
cleaned both switch stacks thoroughly so I know that's not the problem.
#2 1 year ago
If they register during test you would think it's just an adjustment issue.
#3 1 year ago
Quoted from Buzz:
That's what I thought Buzz. But they are gapped so well and the switches were cleaned with 2000 grit sand paper. I'm starting to wonder if they are supposed to
score or not. I would think so. Could a capacitor across the leaf switches be an issue? Probably not if I can get them to trigger in switch test. I'm stumped
#4 1 year ago
The caps across the switches in Bally games often need replacing. If it has caps on it then I would replace them. Search around here for the correct ones. The caps help the computer pick up a quick hit. If they register when you manually activate it, but when a ball quickly goes over it and it doesn't work, I would replace the cap.
These are what I got
ebay.com link » 100 Pcs 047uf 50v 20 Z5u Axial Ceramic Mlcc Capacitors Sa055e473maa Avx
Recommended from this thread
https://pinside.com/pinball/forum/topic/replacement-switch-capacitorolder-bally-pins
#5 1 year ago
If you sanded too much then maybe it's the contacts. Switch test opens or closes signal from the board.
#6 1 year ago
You could manually jumper to prove bad contacts
#7 1 year ago
I think it's the capacitors on the switches. I'll have to change them tomorrow and will report back.
#8 1 year ago
I'm pretty certain that some of the rollovers only score points when in/out of multiball. Have you tried playing around with it with the glass off to see if they score at different times during the game?
#9 1 year ago
No, but I'll try that as well. thanks thrillhouse
#10 1 year ago
Hard to believe but, 2K sand paper takes the plating off the contact. Only clean with non abrasives.
#11 1 year ago
Quoted from jj44114:
I've used it for years. It's very light on the contacts and 2-3 swipes is enough.
#12 1 year ago
Quoted from Barakawins1:
Thrillhouse is on the right track, those two star rollover switches only score when you've got a ball locked in the adjacent saucer. When there's no ball in the adjacent saucer, those respective switches don't score. It's a way to reward score when making the shot but already have a ball locked.
Third Coast Pinball
$ 259.95
Pin Stadium Pinball Mods
nvram.weebly.com
$ 279.95
$ 149.95
Allteksystems
$ 50.00
