I was doing some work on a friend's TAF a few weeks ago and noticed something strange. There is a solenoid on the side of the swamp scoop that basically pushes the ball over an inch into a VUK. The side-to-side solenoid was intermittent, sometimes waiting for a ball search to move the ball over to the VUK. I fired it in test mode and it moved veeerrrrryyyy sloooooowly. Sometimes it would move quickly, but not as fast as the typical 'pop' you get from a solenoid w/plunger.
I had a coil and sleeve on hand, so I swapped them out real quick. Didn't make a difference. The fixture moves smoothly by hand as well. It seems like the power is intermittent or not strong enough to bring it over. It doesn't work in test, so I'm not sure why it works in 'search' mode. He said that it gave up the other day and won't kick the balls out at all.
I don't know where to go from here. Any ideas?
