(Topic ID: 173959)
Tech: 74 ChiCoin Big League
By northside-irish
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by Otaku
#1 4 years ago
I have a ChiCoin Big League, a solid state pitch & bat in an arcade game cabinet. The game mostly plays but after a while there is a delay when pitching or hitting or it stops altogether. Turning the game off and on again will sometimes help but a full game is rarely consistent.
I checked the chips one by one using the diode setting on my DMM and as far as I can tell they're good. In looking at the schematics, both the pitch and bat functions 'run' through capacitors that are the original from1974. Do these ever go bad?
#2 4 years ago
Capacitors definitely go bad. You can source replacements by finding capacitors with the same uF rating online. The voltage rating can be (and is OFTEN) higher, but it cannot be lower. So for instance if your cap says 10,000uF 16v, you can substitute this with one that is 10,000uF 100v. These are exact matches besides the current it can handle. Obviously "100v" can handle your "16v". But you CANNOT substitute the uF value like this. (Read below)
Sometimes on the really old stuff they don't make that value (uF) anymore and that's when you need to start sourcing a similar replacement, but then the game plays a different speed or something else is messed up, etc., and it's really a pain it seems so hopefully you can get direct replacements. I would wait for somebody else to chime in as well. Sometimes there's just those capacitors that never seem to go bad and it's some other part that goes bad or is out of wack.
