(Topic ID: 261104)
Team One rule set
By Billc479
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by HowardR
#1 4 years ago
I can't find a booklet for this machine, I suspect it may not have one. Regardless, are there multiple drop targets scoring 5000 points during three ball play versus five ball play? I have seen other titles where the rule set changes with number of balls selected.
I keep mine on three ball, and it seems like an unlit drop target will score 5000 instead of 500 points - its not always the same drop target, so I think it indexes the same way as the lit drop targets. Thanks
#2 4 years ago
The 5k target moves around, and it is indicated by a light under the plastic behind the target. It’ll be obvious once you know what to look for. An unusual way to indicate scoring, for sure.
I don’t know the difference between three ball rules and five ball rules, but I doubt any changes would impact the way the 5k targets work.
#3 4 years ago
Quoted from Billc479:
You’re correct, I’ve been told Gottlieb didn’t make manuals for add-a-ball pins. I used to have a Team One, and that’s how I learned about that. It is a fun pin, I actually like it better than Abra Cadabra.
#4 4 years ago
Surprisingly, Add-A-Ball machines didn't come with a manual.
Quoted from ryanwanger:
ryanwanger is right. 3ball & 5ball settings don't affect the 5k targets.
#5 4 years ago
Well, that's what I was afraid of. So, most likely my problem is with the relays in the relay bank. I have noticed how sensitive the rack is to twisting, and its hard to adjust the contacts properly when the final orientation is different from the rack's final resting place. I'll remove the field and work on them again.
Thanks to all for the help and comments.
#6 4 years ago
This is controlled by the discs on the Target Bank Spot relay (KS) which is a mini stepper (AS type).
The Pinball Scientist
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/team-one-rule-set and we tried optimising it for printing. Some page elements may have been deliberately hidden.
