I am stuck on the start up sequence, and need a sanity check. I think the issue is the AX relay, but...
When starting the machine, the Lightbox sequence will go to "zero", the drop targets reset, and the score reels all return to zero. The balls to play unit indexes up to light up 5 to play, but continually hammers as if to go to 6, 7, or higher to play. Also, the R relay does not energize, thus the TILT light is always on.
So my questions are: When is the AX Relay Reset supposed to energize? When does the Hold Relay energize to turn off the TILT light? Am I correct in thinking the issue is with the AX (Reset Completed Relay)relay?
I can't find a start up sequence for this machine, and the generic notes I can find are not helping me. Thanks in advance.
Bill C
