New! Dark mode!
(Topic ID: 270433)
Teachers Pet Startup Problems.
By Pinaddict91
4 months ago
  • 39 posts
  • 9 Pinsiders participating
  • Latest reply 4 months ago by paulace
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 4 months ago
Just got this game and nothing works on game besides the outholes.when i turn game on the only way it comes to life is if i hold in the left flipper button then it will light up and if i put the ball in the eject hole it will eject besides that DOA! please help any advice would be great.
#2 4 months ago
This is the normal power up procedure for this era of machine - connecting the power cord and then pressing the flipper button or closing the coin switch will energize the lock or hold relay and distribute power to the circuits.
Placing the ball in one of the playfield eject holes and having it ejected from the hole is normal when the machine is in game over mode.
What happens to machine when it's powered on and the ball is placed in the outhole below the flippers? What happens when you press the red credit/start button on the front of the cabinet?
#3 4 months ago
The only thing that happens is the lights stay on when the ball is in the outhole after pressing the front button. The switch stack is badly bent so no contact is made to be able to get the ball to eject to shooter lane but i manually used my finger to push it and still nothing happens once the ball is their.
#4 4 months ago
Do you have a high quality scan of the schematic that you can post?
#5 4 months ago
Is it set to free play? If not, are there credits on the machine?
#6 4 months ago
Yes i manually put credits on the wheel and still nothing but it does subtract a credit from the wheel when i press thw front button twice but nothing else works as stated before besides the eject holes when i press the buttons in at the same time. Does anyone have a copy of schematic they can post. I also need to know what size fuses go where so i can replace them with new. Thanks
#7 4 months ago
Quoted from Pinaddict91:
Test them first. No need to waste a good fuse. Have you tried pushing the start relay?
#8 4 months ago
Quoted from currieddog:
Yes i pushed the start relay unfortunatly game still does not respond
#9 4 months ago
What happens when you manually push in the coin relay or replay relay?
#10 4 months ago
Quoted from fredsmythson:
The game seems like it wants to start up but just buzz. Nothing works on the game besides the eject holes & once i let go of either the game fully turns off.
#11 4 months ago
If the machine powers off after the ball is ejected from one of the four kickout holes, then there might be a burnt coil/solenoid on one of the kickout hole units or on a related circuit. Check for any burnt or damaged coils/solenoids throughout the machine.
#12 4 months ago
Well i found out that the reason why it was not turning on was because the lower cabinet tilt was to close together now when i press the front button the lights come on and stay on but thats it. Side note i do NOT see any burnt coils that i can tell. I am trying to figure out how to make it free play once i have credits on the wheel to see if thats the peoblem.
#13 4 months ago
http://www.pinrepair.com/em/index3.htm#free
#14 4 months ago
Best resource on the web Except for The Pinball Resource, of course!!
#15 4 months ago
I tried that still not fixing the problem. Anyone that has a schematic for a teachers pet could email it to me?.
#16 4 months ago
Pinball resource probably has one
#17 4 months ago
Thanks but that does not do me any good when shipping takes awhile and i need it working this week.
#19 4 months ago
Read the schematic best i could still no luck even replaced qll the fuses with no sucess. Wondering if anyone is avaliable to get on video of some form to walk me thru with some help want it working for a get together this weekend hopefully any help would be appriciated.
#20 4 months ago
You can make a vid of what's happening, post to YouTube, and then put that link up here.
#21 4 months ago
I'd help but these days most people can't get me the high quality copy of the schematic I need, from (for example) Staples ($2) or Kinkos ($6)
Or how about this
https://pinside.com/pinball/forum/topic/an-em-pinball-online-repair-clinic
#22 4 months ago
Generally when I get a new EM that isn't playing, I go through and inspect every relay, switch and wire in the whole game. Seriously on a one player game it doesn't take as long as it sounds to go through everything. Manually close all of the relays and make sure the switches all close and open properly. Look for broken switch blades, missing switch points, wires that look like they are attached but actually hanging loose, burnt coils or anything else that looks funny. Then I generally like to clean the rivets on the steppers and make sure they are moving smoothly by stepping them manually. Check all the interconnect cables from the cabinet to playfield and backbox are correct and not laying on relays on the bottom board and impeding motion. I like to clean the pins on these cables with an abrasive plastic wheel just to get better connection. Checking and adjusting the score motors and switches is also a good idea and easy on a one player game. Score reels are probably not your current start up issue but you never know. A lot of times they can cause a continuous running score motor. Checking the tilt and slam tilt switches is a good idea too. On a game like Teachers Pet there is a kick switch in the cabinet on the bottom. Make sure it is not stuck closed.
On my game I installed an On/Off switch in the normal location. When I flick the switch "on" the whole game lights up and all I have to do is hit start.
#23 4 months ago
Sorry for the slow mo quality with the light flicker. There is a lot of action in the first couple of seconds and at the end after everything is reset.
#24 4 months ago
Quoted from John_I:
Not sure, but I think you want this switch to be closed to start a game.
#25 4 months ago
Quoted from JethroP:
You are right. I had it backwards. This would definitely be a good thing to check on a machine that is not starting properly...
#26 4 months ago
Ok when i get home ill make sure it is closed i do know while the game is on if i mess with that switch the game will cut off so does that mean its not closed in the first place?. (I notice when it touches the bottom part of the board it turns the game off so should i make sure the contacts are both together and then make sure they are pulled away from the bottom of the board with like a zip tie or something?. I have an on and off switch as well. Currently as jeffro knows the only thing working on my game is when i press the 3rd relay on the right bottom playfield if i touch the right flipper at the same time the 100s score changes and the right flipper moves.
#27 4 months ago
You are right, it is closed already. If that switch is open, then NOTHING would work at all.
My suggestion is to buy a schematic. I assume you have a digital volt meter and understand basic electrical circuits. John_I made very good recommendations above (post #22). Start tracing the power from the source to there it stops. It's can be a slow but methodical process. You may have something as simple as a broken wire or solder joint, or perhaps a misadjusted switch or burned up coil. While you may be able to find the problem just looking visually, I suggest a schematic and voltmeter.
#28 4 months ago
I have a volt meter and a schematic is coming in the mail but im more of a visual learner. Ive used schematics in the past they never help
#29 4 months ago
Quoted from John_I:
Could u send me close up pics of all your bottom board switches and the reset bank attached to bottom of playfield pics i want to make sure all the contacts are open where they should be and closed where they should be. Please. If not if anyone in in virginia that wants to make some money i could use a good williams tech
#30 4 months ago
#31 4 months ago
Yeah I know the game is filthy inside the cabinet, but it works perfectly.
20200616_102144 (resized).jpg20200616_102156 (resized).jpg20200616_102206 (resized).jpg20200616_102218 (resized).jpg20200616_102229 (resized).jpg
#32 4 months ago
Beautiful well loved game i hope i can get mine working like yours i looked at my relays none are in that bad of shape im thinking its the bank attached to the playfield.
#33 4 months ago
When I got my Teacher's Pet it didn't work. Found many problems...broken wires and solder joints. They were not obvious looking at them. I literally had to pull on each wire and solder connection to find them. Also dirty switch contacts and incorrectly connected wires. Definitely needed the schematic to trace the wrong wires. It's tedious and time consuming, but that's part of the hobby.
It's a great game!
#34 4 months ago
Thats what makes it so difficult is i paid so much for it because i know how awesome the game is its just getting it their. I guess if i cant figure it out in a couple weeks ill have to find someone who wants some money to fix it.
#35 4 months ago
Had a friend help me. The game is fixed problem was a loose jones plug but also mostly in the sequence bank was not adjusted properly thus not making proper connections when it came down. Thank u everyone for their help.
#36 4 months ago
I helped him get it sorted yesterday. As he said, a jones plug was "plugged" so that the males were between the female openings, not in them. Another jones plug wasn't pushed in all the way. And the big sequence bank of latched relays attached to the underside of the pf was majorly screwed up - all the rollers were in the wrong position, supposed to be between some switch leafs, but were on top of them instead, so none of the switches in those banks were opening/closing correctly. (How does that kind of stuff happen??) Luckily, the switch leafs weren't mangled, so I adjusted/cleaned all the switches on the latched relays for proper opening/closing once the rollers were in the correct position... 3 hours of work.
Playfield and backglass were in great condition - it's a fun game!
#37 4 months ago
Quoted from paulace:
What a guy he is always helping where he can goes to show pinball has helped me enjoy life but more meet some awesome friends.
#38 4 months ago
Glad you got it going. Good thing about the old one-player games is they are fairly simple. Once they have been gone through by someone who knows what they are doing, they seem to be very reliable. Good luck!
#39 4 months ago
Yeah, one thing that I love about working on EM's is that the components aren't as delicate as SS ones. If that Jones plug that was plugged in between openings had happened on a SS game, transistors would have blown for sure. This baby just took it and smiled...no harm done.
Various Novelties
Pinball Photos
$ 334.95
German-Pinball-Modular
$ 499.95
Pin Stadium Pinball Mods
$ 8.50
$ 199.00
Medisinyl Mods
$ 9.00
Hdmike mods
$ 87.00
$ 3.00
Docent Electronics
$ 3.00
Various Other Swag
Project Pinball Charity
RobTune
Apparel - Unisex
$ 69.99
$ 144.00
Lighting - Backbox
The MOD Couple
$ 67.95
$ 65.00
$ 28.25
The MOD Couple
$ 5,999.00
The Pinball Place
$ 20.90
Apparel - Unisex
