I cannot get my Taxi to go past 100k on the spinout shot. Most times it will max out at 75K. I read the thread over at RGP that discusses this, but I have not been able to improve the situation. I've take the spinout ramp apart and cleaned it. Tighted up all the support posts. Removed the launch cage and cleaned a couple of burrs off it and JB welded a loose support, and then polished it up. Replaced the spring, tried to center the plunger as best I could, and no improvement. I even cut up my old spring and tried adding half the old spring to the new spring. It is the red spring too, btw. Pitch is set at 6 degrees.
The only area that needs to be fixed is the top of the spinout ramp. The piece that fits on top that keeps the ball down in the funnel is broken on one side. Since one side can move, I wonder if this is robbing momentum from the ball?
