(Topic ID: 222400)
Taxi: Resets constantly on startup
By Richthofen
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by maestro
  • Taxi Williams, 1988
#1 1 year ago
So I have a taxi who developed 'reset' symptoms. However when it first happened it was periodic and the game when allowed to sit in attract mode for a few minutes, would then play games without resetting. Now, as soon as the game boots and kicks a few coils during the boot, it 'resets' instantly and stays looping like that. When the problem first started happening, wiggling / pressing the cable connection on the power rectifier board fixed it. I am guessing its a 5v issue, and that some component is bad or the game needs some solder reflow but I am unsure how to test that theory on the board. Assume I am an idiot with a pinball machine and a multimeter. What's the first thing I should check, and how do I check that thing?
#2 1 year ago
+12volt unregulated is dipping down below 10.4 volts , your issue is not uncommon with system 11 mpu's , i had issues that were fixed with a new power supply board , if you have clips on the meter monitor your +12 while you start it up and see what happens to the voltage while things are happening when you play and such , i mean either 12 is being pulled down by something or the 12 is just not stable , i noticed that it happened more for me when the back box was closed instead of opened and i figured heat was effecting my taxi in the back box so i placed a hair dryer on parts of the back box and heating the power supply +12 was very sensitive so i replaced it and long story short it works much better now , so get clips be very careful not to let any thing slip and short out , monitor your unreg +12v ( 5v is derived from the +12v if i remembered right) but the reset is caused by the +12 line , also sound board can pull it down so you can unplug power to it and test +12 , for me the 5volt never was out of tolerance
#3 1 year ago
Agreed, rebuild your power supply and reflow header pins or replace with new board.
#4 1 year ago
Quoted from Dragon:
Ok so which pin is 12v and how do I check its voltage?
Quoted from maestro:
Normally, I'd just buy the xpin repro board and be done w/ it. But I'm on a little more of a budget. Is there a good guide to power supply 'rebuilds'?
#5 1 year ago
Quoted from Richthofen:
If your High Voltage tests ok, then a power supply rebuild normally is just a cap kit and resolder the male header pins. https://www.greatplainselectronics.com/proddetail.asp?prod=W12246-PEC-KIT
#6 1 year ago
Quoted from PinballManiac40:
I have the HV/Display fuse out of the game because the game has LED displays.
#7 1 year ago
Continue as Maestro and I have suggested.
#8 1 year ago
I get my kits from big daddy enterprises. He typically provides a guide that indicates which components get replaced on the board.
$ 54.99
$ 94.95
$ 17.00
Metal-Mods
$ 67.95
$ 22.50
$ 399.95
Pin Stadium Pinball LEDs
