I'm having a hell of a time with the ramps in my Taxi. The Arrivals ramp goes back in just fine, seemingly. But the Departure ramp is turning out to be a real pain.
The main problem is that I can do two of the following three things:
- Secure the right side of the Departure ramp plastic to its post
- Rest the middle of the wireform ramp on the right-most post at the Marilyn drop targets
- Rest the end of the wireform on the post next to the left return lane.
Doing the first two leaves the end of the wireform ramp way off to the right of the post it needs to sit on.
Doing the last two leaves the right side of the Depature ramp (the wing where the switch is attached) way too high above the playfield to be able to screw down.
Doing the first and third options has a variety of consequences, but most of them involve not having nearly enough clearance for the ball to travel along the Arrival ramp's wireform.
These ramps clearly worked before I took the thing apart, but I have no idea how. I could apply a bunch of torsion to the ramp and force it to fit, but that just doesn't seem like a good idea.
I've also tried replacement ramps, but the replacement Departure ramp is even worse of a fit. I'm working with the manufacturer to try to figure it out.
It's possible that I have the ramp posts in the wrong spots. Is there anyone who owns a Taxi that can tell me the measurements and diameter (thick/thin) of each post that holds the two ramps and the Spinout, and where they go?
