Problem was if the ball does not hit the spinout advance switch from a weak plunge but enters the spinout bowl then drops to the kickback, the ball will sit until ball search. If it hits the spin out switch it works fine.
The plunger lane switch wireworm had broken off so I assumed that was the problem. Replaced that switch, tested all associated switch
edges and all good. But this did not fix the problem. Any hints? Thank you...
