Quoted from MonkeyGrass:The segments on the right hand upper side (player 2) are on constantly. The segments on the left (player 1) flash in accordance with the jackpot display. If that secondary display isn't flashing, like while in meter mode, the segments are not lit.
This is where we start getting in to some real issues. The glass for player 1 and 2 is just one long piece of glass; they're not actually seperated at any point. The segments for all the displays come in and the digits are strobed. But with the jackpot display behavior...you have have a bizarre strobe issue.
That resistor pack looks pretty gnarly. Someone did a lot of board work to that area. Did they replace it? Without being able to inspect it in person with a maginfying glass, I don't know. But they are pull ups for the data for the displays. If that wasn't cleaned up and installed properly, it could cause some issues. The segment data for the player 1/2 (display 1) run through SCR5 and SCR2, pull up resistors/cap packs pulled from the 6821 at U41.
But I'm starting to wonder if you've got some kind of strobe issue...which I'm not sure offhand where the digit strobe data comes from...or why all the *p-segments* would be locked on. If the driver was shorted; they'd always be on. I really need to see what the jackpot display and display 1 have in common. The player 2 area is always locked on but player 1 only locks when jackpot is displaying. Feels like a strobe issue, but I've really gotta look and figure out what they have in common. It's been a while since I've actually looked at these schematics; I'll study them for a while and see if I can't figure out some ways of narrowing this down. It's possible that's a red-herring and one of the chips is just "failing" and the excess load isn't affecting it. But the jackpot display isn't alpha.....my head wants to explode. A HV supply that's gone too high can cause this too; as the segment driver chips have 90V going in to them.
The thing to remember is that *every* segment in a display is connected together. If you light up one segment the power flows through ALL of them. What it does is very rapidly strobe digit locations; constnatly changing the segment strobe data to match what segment it's on. So the fact you have P lit on one side constnatly and sometimes on the other really starts to throw a loop...which is why I said I need to really study segments.
I just have to sit and figure this out without being able to throw a logic probe/DMM/scope on things.
If you swapped displays and the problem stayed with the display; then you probably have a segment driver not working. The segment that would do what you're describing is "f". It it's the top display; the F segment comes in on pin 5 of U10, out of pin 4, then goes to pin 6 of U16 and out of pin 13 through a resistor to the display. If you know it's not solved by plugging in to another machine or wiggling the data cable...then U10 and U16 would be suspect.
Post edited by dewdude82: I'm getting p-segments and commas confused again.
