So after redoing my Taxi, the pinbot flasher in both the backbox and playfield are not working. In the test mode I can hear the relay clicking which should activate it. I’ve checked under the playfield for loose wires and changed both bulbs to eliminate that. I checked the connector and it appears strong. Where should I look next? It can’t be a fuse as the other flashers would stop functioning too.
