(Topic ID: 269755)
**SOLVED** Taxi No Sound But Lots of HUMMMMMM
By Pindiddy
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by Pindiddy
  • Taxi Williams, 1988
#1 3 years ago
My Taxi has lost its sound. It worked fine and now no sound, just a constant hum. From the moment the power is flipped on the hum starts. The usual “BONG” noise does not happen. The game boots up fine and a game can be played without any other issues, everything works as it should. The cabinet volume control does not change the volume or loudness of the hum. The sound test button on the MPU does not do anything either. I read in a different post that the hum can be caused by a grounding issue so I made sure that all of the screws for the audio and mpu boards were tight. No change. I disconnected and reconnected all of the jacks that run to the audio board and the large jack that supplies the power from the power board. No change. I’m up for suggestions. I’m suspicious of the Yamaha YM2151 chip. See the pic for a good look at the Yamaha chip.
14240F3E-E8B1-469F-89EE-89AC5DFD95DF (resized).png14240F3E-E8B1-469F-89EE-89AC5DFD95DF (resized).png27F5EEF8-3A53-4474-8084-597CBDDCA42D (resized).png27F5EEF8-3A53-4474-8084-597CBDDCA42D (resized).png
#2 3 years ago
Quoted from Pindiddy:
Start by checking for power on the sound board. You need ground, 5, 12 and negative 12 volts.
#3 3 years ago
Voltages checked out ok. Working from right to left I got +4.93, Ground, -14, and +12.
#4 3 years ago
I also swapped out the sound board from Rollergames into Taxi and vice versa. Taxi will boot up with the normal BONG tone as it should. Rollergames now has no sound but does have the hum, so it’s definitely something wrong on the sound board. How do you troubleshoot a soundboard???
#5 3 years ago
I thought I would check the capacitor readings while I had both boards out and found the following readings. It seems like C32, C29, and C12 are all reading much lower than Rollergames. Also, C26 on Taxi had continuity while C26 did not on Rollergames. Could these cap differences be the issue?
F8DD0E43-8BD4-4BD9-930B-AD26055E2970 (resized).jpegF8DD0E43-8BD4-4BD9-930B-AD26055E2970 (resized).jpeg
#6 3 years ago
Bump for advice
#7 3 years ago
The rare protype with the C+C Music Factory sound track.....
Things that make you go Hummmmmm
1 month later
#8 3 years ago
Capacitor C26 was the issue. It had continuity when I checked it while on the board. After removing and replacing the cap all is well. No hum and the sound board is functioning properly. The moral of the story is never trust a cap with continuity, it’s bad...
$ 899.00
$ 22.50
$ 27.00
$ 54.99
$ 18.95
$ 18.95
$ 899.00
4,000 (OBO)
Bay Shore, NY
$ 99.00
Cabinet Parts
Gizmorama Pinball
$ 17.00
Metal-Mods
$ 109.00
Middletown, OH
$ 12.50
RoyGBev Pinball
4,495
West Chicago, IL
$ 36.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/taxi-no-sound-but-lots-of-hummmmmm and we tried optimising it for printing. Some page elements may have been deliberately hidden.
