This one had me stumped.
We just got a Taxi. Basically cabinet, playfield, and a box of mismatched boards and wire harnesses. After acquiring ROMs, a proper LED display, and fitting everything back into the machine, the game will boot into attract mode and does a quick ball search even with the 2 balls present.
Display works, lamps work, sounds seem to be ok. The switch matrix is all 'fudged' up. I don't believe any switches are registering. Test report shows ground row short, row 1. When I go further into the test menu. The game flashes a ground row short for every row of the matrix. See video.
The test switches are hard wired out of the matrix, so they are working.
The problem exists even after removing J8 and J10. Here's the crazy part. In switch edge test, no connectors, if I touch any pin on J10 with my finger. It fires a sling shot and displays a ground row short on the display. How can touching 1 pin and nothing else throw a fault??
What the heck am I looking for??
