Me again, LOL
Ok, not sure what I did while I was changing the flippers out or when I was cleaning the Marilyn drop targets or when I reflowed the solder to the relay in the backbox but now it's acting a little weird and HOPING someone knows what this is and that it's an easy fix as I have no clue where to even look.
When I activate multi ball and then lock one ball in the Express Lane 1 (on the right) and the countdown begins, then drain the other ball, the machine releases the locked ball as normal but it continues to flash all the flashers like it does when the countdown happens when you are needing to lock the 2nd ball in the Express Lane 2 for the 300,000 score. Then what's even weirder is if you lose the last ball (BUT only if you previously locked a ball in Express Lane 1), the end of ball sequence doesn't occur, it just sits there flashing all the flashers, playing the music and the regular callouts. The only way I can get it to end the ball is if I shake the machine and get a danger, then it ends like normal.
The drained balls do get kicked towards the shooter so it does detect the balls there?
So what in the world did I do as it didn't act like this before I did the changes listed above.
Thanks again for any help.
