I have a Taxi with a Rottendog MPU that suddenly none of the lights on column 3 are working. I have LEDs in the inserts and you can see them very faintly light up when they are supposed to. They also do this in attract mode. I have traced the wire and it is not broken. I have tested Q62 and it tests fine with a DMM (getting .57 on each outside leg with red lead on tab). I have jumped the tab on Q62 to the tab on Q64 while in attract mode, and the lights come on and flash like they should. That makes me suspect the transistor at Q62, but being that it tests ok, has me scratching my head. I am unfamiliar with the behavior of the Rottendog board so it may be something else I am not aware of. Does anyone have any suggestions of where I should look next and what to test? Thanks for any help you can give me.
