(Topic ID: 188958)
Taxi - done restoration but problems
By Cheese_WizardPQ
6 years ago
  • Taxi Williams, 1988
#1 6 years ago
* also post in the club
Resto finally over. No credit dots but right GI and left flipper don't work. Still a lot of tuning on the bumpers too. They don't trig in switch level.
The taxi cab toy on the right ramp is a test. Looks big in pics but fits ok. I might add micro leds in it to flash with the ramp.
I'm 90% happy with this 1st resto. I Lerned so much for the next one!
Any idea what I should look for my dead flipper? Fuses are good. It worked well at first and died. I saw some sparks at the coil when I flip...
For the right GI I presume it's a short somewhere or a cold solder?
#2 6 years ago
Solder joints on the coil lugs first, then thin wire from lug into the coil for breaks or cracks.
#3 6 years ago
Nice job on the resto...
#4 6 years ago
Quoted from LTG:
Everything looks good.
Is the flipper switch be the problem?
When it was working, the flipper was shaking like crazy when holded up..
More pics if it can help
Thank you very much
#5 6 years ago
Quoted from cosmokramer:
Thanks! Not a Brian Kelly yet but I learn!
#6 6 years ago
Your EOS needs to be filed clean and tension holding it closed.
#7 6 years ago
Nice yellow color inside the cab! Did you spray or roll?
#8 6 years ago
Nice job on restoration but that toy cab looks hideous
#9 6 years ago
Quoted from LTG:
This....
#10 6 years ago
Quoted from KornFreak28:
Spray.
Quoted from boscokid:
I wasn't sure myself. Hideous by it's format, it's position or it just don't belong in the game? Thanks for your input!
#11 6 years ago
Quoted from LTG:
You're talking about the twisted leaf on the EOS? Should I buy a new one? I tried to work on it but it's not easy to make everything straight.
#12 6 years ago
I'd replace the EOS switches to match the rest of the resto. Also, doesn't taxi use a cap on that switch to keep the Sparks down? Oh, and upgrade the spring to wpc style, get rid of that plunger sping.
#13 6 years ago
Quoted from Kneissl:
Cab you guide me on what you mean by "cap" and splunger sping.
Cab you find picture from Marco's catalogue? I'm more visual.
Thanks Kneissl
#14 6 years ago
Quoted from Cheese_WizardPQ:
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers vid1900's guide will help you a lot.
#15 6 years ago
Spray.
I think it looks out of place. It took me 10 years to accept LEDs so my opinion may not hold much weight
#16 6 years ago
Thanks Kneissl
Here you go, scroll down the System 11
http://www.performancepinball.com/rebuilding-flippers.html
#17 6 years ago
Fair enough.
#18 6 years ago
boscokid
Now what's your position on leds?
I think it's a must for a lot a 90s games.
#19 6 years ago
Follow LTG's advice: your End of Stroke switch has a very small gap in it (it should be normally closed, and have a fair amount of tension on it). It's not working because the gap prevents high power from getting to the solenoid; and the low power isn't enough to "flip" the flipper.
As for your GI, double check the relay boards for cold solder joints, and reflow solder if necessary. I've found that on both my Whirlwind and Earthshaker, I had cold solder joints on the male pins on the small boards mounted under the playfield, and caused all sorts of issues with the GI.
#20 6 years ago
No advice on the issue, but your restore looks gorgeous!
#21 6 years ago
Always do a flipper rebuild and replace switches. The cost of these things are so minimal conpared to the cost of the game, but yet the impact is one of the largest. System 11 games have a capacitor ziptied as part of the flipper assembly. A rebuild kit will have all the things you need to make them 100%.
And i second the toy cab not belonging.
But great job otherwise
#22 6 years ago
I think you have the wrong type of diode on the flipper switch. I think it should be a black one that is 1N4004. Can you snap a picture of the other flipper switch?
#23 6 years ago
Quoted from EvanDickson:
Man. So good to read that.
Lov you
Canadian lov
#24 6 years ago
I switched the right flipper switch to the left side. It doesn't work even with a proven good switch
Is there something I should look in the backbox since the problem is not the switches or the coil?
Quoted from mbaumle:
Are you talking about this board?
#25 6 years ago
#26 6 years ago
Thats one of the gi boards. You sure all the fuses are good?
#27 6 years ago
Yes
Anyways. I'm sending the game to my repair guy. There are things that only years of experience can buy. I'm done with this game. We need a break
#28 6 years ago
You can get reproduction GI relay boards. I replaced one of mine in my Taxi with a repro one as it was cheaper and faster than repairing IMHO
Also yeah get rid of the toy taxi. It's blocking to beautiful ramp artwork.
#29 6 years ago
You can trade the playfield GI relay board with the backbox GI relay board to verify it is the problem. They are interchangeable.
$ 899.00
$ 12.50
RoyGBev Pinball
$ 22.50
$ 18.95
$ 99.00
Cabinet Parts
Gizmorama Pinball
$ 109.00
$ 27.00
4,000 (OBO)
Bay Shore, NY
$ 899.00
4,495
West Chicago, IL
$ 36.95
Middletown, OH
$ 54.99
Playfield - Plastics
The Pinball Scientist
$ 18.95
$ 17.00
Metal-Mods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/taxi-done-restoration-but-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
