Taxi display problem and was hoping for some guidance. Lower left digit out, the one that shows
First digit of match at the end of game. Replaced U1, and swapped U17 and U18, traced and relfowed.
Put display in another game and same problem. Aside from a possible break under the display glass itself anything else I should try?
If it is an under glass problem are there LED placements for the whole board?
Also, not sure what readings I should be getting from the legs from the glass to the board. Thanks!
