(Topic ID: 255952)
Taxi credit/start button
By NJFISH
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by GRUMPY
  • Taxi Williams, 1988
#1 4 years ago
Hi all, first time posting since I could not find a solution searching the site. The credit/start button on my Taxi game is not working. Not only that, (forgive the terminology) the thin bent wires on the coin door that I would normally use to add credits are not working either. The game has not been used in quite some time but it boots up with no errors, previously it worked fine. I checked all of the connections to make sure they were tight, and I did not see any loose or disconnected wires on the start button. Can someone point me in the right direction? Lights, sounds, flippers, etc., all seem to work normally. Just can't start a game. TIA.
#2 4 years ago
What are the errors?
Does it say something about factory defaults? If so, then the game settings were probably lost and the free play setting along with it.
Have you changed the batteries? Have the batteries leaked onto the board?
If you're familiar with the settings menus, the free play setting is adjustment 23, which should be set to yes.
[edit]:Nevermind, I must have misread.
#3 4 years ago
Hmmm. If it doesnt start a game sometimes it means it is missing balls or cant located the 2 loaded (bad trough switch). I would enter the service menu and test your switches, include the start button. You can check if it is working there or not. Make sure it is showing both switches in trough are good.
#4 4 years ago
There are no errors indicated. I can't change any settings because the start button is not working. The batteries leaked about 10 years ago and I had it repaired and the battery case moved. I didn't think about checking the balls, but I know they are there but maybe they are just stuck??
How do I check the switches in the trough with the service menu? Again, I thought the start button is used for selecting choices in the menu and without it working I can't select any changes.
#5 4 years ago
Quoted from NJFISH:
You are correct, the start button does make the changes but isn't needed to do game testing. You also don't really know if the start switch is working until you place the game in switch test and then push it. So far everything that you have described could be some other issue but you won't know for sure until you run the test. Check all the switches for activation, but also make sure to hold each switch long enough to register 4 times and that only the one switch shows on the display. If 2 or more switches show up on the display you have other issues. You also need to remove the balls while testing for other switches. With balls removed and no switches pressed nothing should show on the display, it if does you have a switch that is stuck closed. This will need to be fixed first to continue the test.
#6 4 years ago
Quoted from GRUMPY:
Thank you. That was helpful. It looks like switch edge 07 is an issue but I can’t locate that switch. Is there a list of them?
#7 4 years ago
Quoted from NJFISH:
You might not be interpreting that correctly. The full manual is downloadable as a PDF from IPDB.org.
The 07 may just mean that the game is in switch edge test mode, depending on what you are seeing.
If it really is switch 07, it's the slam tilt switch. Switch matrix is shown on page 31 of the manual.
#8 4 years ago
I’m getting there. Lol. 07 is the “slam tilt”. Not sure if this is related but it didn’t help when I jumped the broken white wire.
1C58BA20-9C1A-4BCF-9081-1335ECBAB481 (resized).jpeg1C58BA20-9C1A-4BCF-9081-1335ECBAB481 (resized).jpeg
#9 4 years ago
Quoted from NJFISH:
I’m getting there. Lol. 07 is the “slam tilt”. Not sure if this is related but it didn’t help when I jumped the broken white wire.[quoted image]
That is not a slam switch. The slam switch is on the back of the coin door, it keeps people from kicking the coin door.
#10 4 years ago
Resolved. Broken wire. Soldered and all good. Thanks for help.
#11 4 years ago
Playball!
$ 899.00
$ 22.50
$ 18.95
$ 18.95
$ 54.99
$ 17.00
Metal-Mods
$ 449.00
$ 99.00
Cabinet Parts
Gizmorama Pinball
$ 27.00
$ 899.00
4,495
West Chicago, IL
$ 449.00
$ 109.00
$ 399.00
Hartville, OH
$ 36.95
