Just when I thought everything was going good, another issue popped up.
I was going through the top of the playfield replacing the lights with LED's and as I was fixing to start on the backbox, I noticed the left side of the lights were very dim. I tried replacing one of the dimmed lights and when I plugged in the LED, all the lights on the left side went out, about 7 or so. The LED I put in was a comet 1 SMD LED. When I took it out, the other left side lights came back on but are still dimmed. The lights currently installed are small frosted dome LED's and I just wanted to put some brighter LED's in.
So not sure what could have happened while I was replacing the top playfield lights to cause this? I did accidentally pop off a switch wire on a ramp that I had to resolder but didn't notice anything else?
Hoping it's something simple.
Thanks for any help.
