My original post got sent to the Buying Advise area. If you want to see that, it is here:
http://pinside.com/pinball/forum/topic/target-pool-gottlieb-project-auction-opinions
I have started the clean up process. I pulled the relay/switches board, stripped it, and gave it multiple coats of clear lacquer and tried as best I could to clean things up. Here are some before/after pics.
There is a lot of rust all over. Since I'm trying to do this on a tight budget, I tried using white vinegar to deal with the rust. I let the parts soak for 24 hours and hit them with a toothbrush. Then I hit them with a coat of clear lacquer. The results are not bad. (Advise: Get the house brand white vinegar from the grocery store for $2.50 gal. The hardware has the balls to price white vinegar for $10.00 gal.).
Here is the shooter. Not show quality, but it looks presentable.
Here is the right flipper rod.
And the left
I also soaked one of the coin chutes.
The parts are not show quality, but I think I can get this machine cleaned up with about 2 gal. of vinegar.
Now I have a couple of questions:
Are the points for the Slam-Tilt normally opened or closed? These are closed. Is this correct?
I had three labels laying loose on the relays board when I pulled it from the cab. They gotta go somewhere. Can anybody give me an idea for locations for these labels?
Tomorrow I need to go shopping for fuses. One is missing and none of the other five fuses are of correct amperage. They are all over-amped. If I can find the fuses locally(without spending a fortune), I should be able to return the board to the cab and power up and see if this pin is going to work.
Wish me luck.
