When a ball hits a drop target, should the ball always score points immediately, or only if the ball <also> hits the playfield switch behind the rubbers (see green arrow in pic) that are behind the bank of drop targets? Trying to figure out if I have the playfield switches behind the targets adjusted correctly.
Also, when a ball goes over a playfield rollover switch, my score motor turns, FS relay actuates, C&D relays actuate. However, I don't ever score points immediately from a rollover. Should I?
Thanks in advance for reading!
