I'm bringing back a Target Alpha back to life. It was dead when I got it. So far I've got it to run through the normal start procedure with a couple of exceptions. Sometimes it will kick out ball #1 and sometimes it doesn't. If i get it to kick one out after I play that ball it does not kick another ball out and the ball count does not advance. If I manually pull in the "O" relay the out hole coil will fire. Its acting like the "O" relay is not getting a strong signal to engage or engage long enough??? Thank you for all your help on advance.
