(Topic ID: 314054)
Target alpha, at game over 4th player is activated
By Radar27
70 days ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 64 days ago by Radar27
#1 70 days ago
I am repairing a T.A. for a friend. So far everything works, but if a one player game is over, after the 5th ball, the 4th player in the backbox is lit, and another ball is ejected for the 4th player. This ball will score, and when it drains, the game is finally over (instead of after the 1st and only player). This also happens with two or three player games. I have the schematics and can read it, but i would be grateful for a hint where to look here (unsure if i should look at a relay in the bottom first or rather the player unit in the backbox, or even one of the score motor switches?). I do not want to fiddle with too many switches at once.
#2 69 days ago
Is there any change if you change the adj. plug from 3 ball to 5 ball (or vise versa) and then play a game?
Also, on a one player game, advance it to the last ball. Then with the playfield raised, close the outhole switch, you should see the Last Ball Relay immediately close.
#3 69 days ago
The Last Ball (BX) relay has 2 coils. When the last ball drains, one of the first things that should happen is that the Last Ball relay's A9735 coil, the one with an Orange-Black wire, should activate. Is this happening?
Can someone with a working Target Alpha verify that this is when the Last Ball relay activates?
#4 68 days ago
Verified on my Fast Draw, should pull in immediately when last ball drains. Unless there are bonus points which will score first.
#5 68 days ago
Wow such good know-how here, thank you all. As for the 3/5 ball game, i have tried that, it behaves the same with 5 or 3 balls. The other hints are great, i will try that tomorrow (the game is in a private event hall, i do not have it in my workroom) and report back with the findings. Greetings from Switzerland.
#6 67 days ago
It almost works. Meaning that sometimes its normal game over and sometimes it behaves as with the fault above. After the last ball it always checks the bonus unit first(with double bonus since it is the last ball) and when that has finished, the BX relay is activated. I have made a video of the bx relay in this moment. It seems to me that it flutters a bit (pulls in, then very quickly resets and pulls in again). Could it be that a score motor switchs timing is a bit off? I have just now realized that i cannot upload a short video here.
#7 67 days ago
Quoted from Radar27:
Upload to youtube or similar and post a link.
BX should pull in and not reset. Then the Coin unit stepper should count down (to check for match) and then the Game Over relay (Q) should lock on.
You can use a bulb tester to check whether the Last Ball reset coil (BXR) is getting power when it shouldn't be.
https://pinside.com/pinball/forum/topic/reading-gottlieb-schematics#post-2634425
https://pinside.com/pinball/forum/topic/em-pinball-circuits-basics-to-not-so-basic/page/2#post-3184715
#8 67 days ago
Quoted from HowardR:
Your cellphone should be able to take a slow motion video in order to see what's happening.
#9 64 days ago
Thank you HowardR your hints are very helpful. I put up my (very first) youtube video of the BX relay here:
I also have checked the bxr reset coil with a test lamp and it does not reset the BX at this time. Therefore, seeing that O and the player unit and the coin unit and DX and E are in the path of current to BX, should i look at the coin unit first? It seems to me that the O relay is adjusted and clean. But the mentioned units have not been touched in a long time, i think. I also noticed that the correct behaviour is usually when i have raised the playfield to watch, but when i have lowered it the fault appears more often. Maybe there is a broken wire involved in the moved cabling.
$ 5.95
The EM Scientist
$ 12.00
Great pinball charity
Pinball Edu
