Hi
ipdb shows on Target-Alpha: http://www.ipdb.org/showpic.pl?id=2500&picno=42296 on the reverse side of the Backglass NO text for "100'000 Points reached" (means I do not see it). The schema shows wiring for it and the bulbs and the relays.
Question: Do You have a Target Alpha - can You see in the Backglass "has made more than 100'00 points" ? Where ?
Greetings Rolf
