mr_tantrum
I have now completed the firmware update, downloaded from https://www.pinsound.org/help/pinsound-plus-help/ for Pinsound+
Diagnostic txt file shows latest confirmed, Baby Driver is on the stick, but diagnostic looks like this (not showing Baby Driver) How odd.
I tried Baby Driver ZIP into boot of drive (not audio folder), rather than unzipped into audio folder. Kicked off conversion please wait.."Error During Zip Extraction"
I tried original, ZIP into boot (not audio folder) Kicked off conversion please wait.., then "Error During ZIP Extraction" I notice the ZIP files is gone from the root, when i pull the USB and plug into my Mac. So its obviously tried to give it a go.
Deleted diagnostic file from Stick, temporarily. Rebooted in machine. Sound didnt work. I assumed Pinsound+ needed that diagnostic file to be there in some shape or form, but I wasn't sure, so I put it back, tested, worked. Took it away, it then obviously ran a diagnostic, as it created the missing file on the USB. I dont know about that..
Dumped John Wick in audio folder, unzipped. Restarted machine. Processed sounds through the 30%, 40%, 50%... Hadnt previously heard the call outs for progress. Now JW and BD are there and playing.
Not sure what I did differently, maybe that firmware, coupled with a boot without the diagnostic file (it was the same one I popped back in..)
I added GetawayHS2-v1_EStroh_Outrun (thank you Eric!) by unzipping and adding to audio folder. It doesnt see it. Tried the diagnostic file removal approach above. Doesnt see the new audio from Eric.
Added Erics work as ZIP to root. "Performing audio extraction"...Then "Error During Zip Extraction"
Added Erics work again, this time in Audio folder, unzipped. "Performing audio extraction"...and then through the 30%, 40%, 50% call outs.
But right now, for my machine, I seem to ave to add zip to root, have it fail extraction, unzip into audio folder on card, run it in and it will do the extraction and go through the 10%, 20% etc...
I'm not really sure..I'll try a few others, see what happens..
HARDWARE MODEL
PLUS
HARDWARE REVISION
3.5
HPS EXTERNAL VOLUME
92%
INTERNAL FIRMWARE REVISION
0076
PACKAGES
GetawayHS2-v10_FullTechno_CustomCallouts_MrTantrum (active)
PINSOUND FIRMWARE VERSION
19.12.2
AMPLIFIER VOLTAGE MEASURED: 26537mV (expected range: 11000mV - 26000mV)
[lowest amplifier voltage measured: 26355mV / highest amplification voltage measured: 26790mV]
