Quoted from Piso:Pinsound told me that the missing startup sound is a software bug that need fixing. I just tried with the latest update (30 october) but still no startup sound... I'm having problem with the pspack too. Tried to contact them again via mail with no luck and also on their forum but it's very limited and every single post needs to be approved... I try here maybe someone can help me.
I want to modify some gains and some shaker options in the original TZ mix that is a pspack file, this is what I do:
- I open the pspack file with their studio pro software
- The software unpacks the pspack and creates a folder called "Twilight-Zone-Original" that contains all the single folders. It also moves the pspack into this folder (check picture 1)
- I then make my gain and shaker modifications and click save. From the date I can see that the "config.pinsound" file gets updated but the pspack file remains old
- Once i turn on my pin the soundboard moves the pspack to the main folder and all the custom settings are overwritten. The cofig.pinsound file remains in the folder but if I try to open this file again with studio pro it tells me that the pspack is missing (the one that was moved to the main folder).
What is the procedure to create a custom sound and shaker package starting from a pspack? Sadly I can't find any guide. Thank you
I'm having similar issues, it's a complete mess. I've also updated to the latest firmware and confirm I've lost the startup sound but not a big issue for me.
What is a big issue is this, I noticed odd behaviour on my working original sounds folder. I downloaded it again from PinSound and noticed the files that were odd had different numbers on the folder name. I want to test that issue but to do so I wanted to completely replace my original sound. I know I can just rename that one folder, but I wanted to get to the bottom of this and any others that I didn't notice.
As it happens, this doesn't work, and not does renaming the folder.
PinSound will not, positively ever, recognise that newly downloaded pspack being placed in the audio folder. It does recognise it when you put it in root, and it unpacks it, but it doesn't put it in the audio folder with the other packs. This ruins my OCD.
It needs looking at definitely. For such a great product, easy dragging and dropping should be a breeze but it's a headache.
