Quoted from kba78:ok @mr.tantrum,
update still does not take, just says no sounds of usb stick.
then tried reinstall sounds, no go.
everything is the same as it was.
I can confirm that it converted all the files from oog to wav.
i thought i read somewhere that there is a update in between mine and the most recent. i am version 1.3, I don't see another update on there website and they still have not responded to emails
Show me the root folder again. Depending on the folder structure, we can determine if you are on the older or new convention.
Until we know what firmware you are on, it is impossible to know if that is your issue or not. Your symptoms seem to point that you are on a legacy firmware, and depending on how old it is there are special instructions to update to most current (It won't just do it automatically). Any sound package you download will have been configured for only the newer firmware convention. While it may convert/unpack, it will never work.
If you don't see a pinsound-self-diagnosis.txt in the root then it is on an older firmware (with the newer firmware versions this file is automatically created on boot every time).
If that is the case then either edit (if it exist) or create a new config.ini file. Inside the config.ini file have these 2 lines:
[main]
debug = true
Reboot pin, wait for PinSound to acknowledge, start a game, turn off pin & remove USB, then open USB on computer and there should be a diag file in the root.
