I have an Arabian nights that was working fine when it stopped booting up and gave the dreaded "check fuses F101 and f106" error. The fuses were not blown.
For this and other reasons I decided to replace the power driver board and had the MPU board, that was damaged, repaired.
When I powered up after I installed the new components I immediatly blew the main fuse in the power box under the playfield. The fuse looked old and rotten and I replaced it. When I tried again the table booted up perfectly and I played 2 balls. All was well. At the plunge of ball 3 everything stopped. No power to the table or DMD. The main fuse is all right and I have lights on the power board. When I try to boot the table now I get one beep and that is all.
If anyone has any ideas of where I check next it would help me a lot. I am getting smarter fast but not quite fast enough. Thanks in advance.
norman
