This one was a real mess when I got it. Was one that probably should have been parted out and dumped but I just couldn't do it. I have a lot in this one, but man it is cool! I have attached a ton of pictures for everyone to look at. This is my first go at a pin restore. Have done several arcade games. I wish I had more pics of the sides, they were as bad as the front. There are some before and after pics here (After followed by before, reversed order when I made the post). The before are as I tore it down so you can see all the pics I took to figure out how to get it back together. You can get a good idea how dirty and bad this thing was. Every lightbulb was burnt out, zero maintenance done, all rubber cracked and destroyed, terrible cabinet damage. After I got all the crap off the play field it was perfect. No damage at all. Not sure how long I will keep this but it will make someone a nice collectors piece now. Thanks a lot for all the help with my questions. Also, I found a formula to mix a sherwin williams paint that matches the side paint very closely, which I know has been a challenge. All art original, repaired by hand to take care of damage. Also, note the Modfather electric chair mod. I also added the wolf and used the tree over the flasher next to him. Looks super cool when it goes off. Finally, added the Metallica side blades which are super cool. LEDs all around and a Cliffy to protect the field. I need to find a better translate, You can still see a little bit of the damage that was on the top back box, I may polish that off a bit better. Other than that it looks perfect.
