Hey all I have some switch issues that I'm having trouble with. I was hoping you could help me figure out what is needed please. I'm not an expert but eager to learn and have some experience but not a lot.
BACKGROUND:
Last week I started to troubleshoot a THING opto issue first (Thing down opto S-84). At this time I was ONLY getting one thing error, S-84 thing down. I removed the hand to inspect the opto board, re-seated the connections and after I couldn't get the "down" opto to register during the thing test so I just ordered a new opto board (assuming I just had a bad opto..easy fix right). Yesterday the new opto board came in so I was eager to install it. I installed the new opto board and to my surprise, I still have the same issue. I made sure that the little arm was traveling all the way across the optos, it's aligned perfectly. I also checked for any loose wires and pushed down on everything firmly.
Tonight I wanted to try and troubleshoot this issue some more so I opened the top and made sure all the connectors were seated properly on the driver board and re-seated some of them. Still had the same one error, S-84 thing down. When I ran the THING test, the "DOWN [X]" would always show as if the switch was stuck on. Even when I un-plug the opto board and reset the game I get the same S-84 opto error.
I figured since I just replaced the opto board, the optos were not the issue so I could go ahead and install the thing hand again back on to the playfield as it is a big PIA to have to keep the playfield up and try and read the DMD. I installed the thing hand and now all of I sudden I was getting 2 errors on the thing... S-84 down opto and now S-85 up opto also.. How did that happen? :_( double checked all the connections, ended up taking the thing hand back out and still have both opto errors @ startup. I put the old opto board back on as a test and still get the S-85 error with that one also. These issues are definitely coming from somewhere else, not the opto board.
The strange thing now is that when I do a thing test, the UP opto actually tests fine..the down does not (same with the other opto board).
There are 2 others issues observed (in case there may be a relation)
@ startup I now get 3 errors in total
Bookcase opto #2
Thing up opto S-85
When doing a switch test, all of the cousin IT targets on the left are not working now either... there are 4 of them.
I didn't notice any blown fuses but I guess next stop would be to check them with a DMM or would you guys suggest I do something else first?
Thank you so much in advance!
