(Topic ID: 85780)
TAF thing eject hole kick-out problem
By Mustache
5 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by j69
#1 5 years ago
The thing eject hole on my TAF stopped ejecting the ball properly. The mechanism is still firing but it doesn't appear to be moving far or strong enough to pop the ball out of the saucer.
I took apart the mechanism and tightened everything up and made sure it was positioned correctly but this didn't fix the problem.
Any suggestions?
#2 5 years ago
Is the coil sleeve broken, dirty or is the plunger mushroomed to the point it is binding inside the sleeve?
#3 5 years ago
Thanks for the fast response. Nothing looks out of the ordinary to me and the plunger seems to move smoothly. I attached a picture which might tell you more of the story than I can. TAF.JPG
#4 5 years ago
I would test the coil to make sure it is good, here's a link on how to http://www.pinwiki.com/wiki/index.php?title=General#Testing_an_integrated_circuit
And I would test to make sure you have the proper voltage coming to the coil. Also make sure you have good solder connections and no broken or cracked insulation on the wires (follow them back a little bit to make sure they're not rubbing against metal).
#5 5 years ago
I would first rebuild the mech (take it apart, clean it, add a new sleeve), and then just pop the plunger with your finger and make sure the contact is on the ball where it should be. Hard to do on this, as the PF doesn't pull forward, and this is so far in the back, but if the coil is firing strong, playing around with these mechs manually usually exposes the issue.
3 years later
#6 2 years ago
Sorry for the bump but mine has also stopped working. The switch registers in the switch matrix but when I test the coil I just hear a dull buzz on and off. The plunger isn't binding in the coil and moves perfectly fine with my finger?
I'll get the multimeter out but has anyone got any suggestions?
#7 2 years ago
I don't know if this will pertain to either of these machine problems, but I can say that particular eject and lockup assembly is highly fussy as related to tilt on the playfield. I sold one of these to a buddy at work and most times I have gotten a call on it over the years I have found the game slowly worked itself until it was leaning very slightly to the left. When that happens the balls will not rest where they need to be in that assembly and the game will either not detect them, or won't be able to fire them out. Before you go rebuilding the whole thing I would suggestion you check the level left to right and see if that helps.
#8 2 years ago
It doesn't fire in the test menu so it's nothing to do with the levelling
6,400 (Firm)
Mooresville, NC
Comet Pinball
$ 999.00
6,000
Sale Pending!
Des Moines, IA
6,750
Lee's Summit, MO
$ 24.99
Lee's Parts
$ 229.99
€ 18.95
$ 22.00
Yorktown Parts and Equip
$ 129.00
LED OCD
Hardware
CPR Playfields
$ 39.99
Lee's Parts
$ 159.00
Sparky Pinball
$ 279.95
$ 38.99
Lee's Parts
€ 95.00
FlipperLED
$ 125.00
pinballmod
$ 369.00
