(Topic ID: 322631)
TAF Switch Column 3 dead, replaced U20 multiple times
By RandyW
2 days ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 2 days ago by Miguel351
#1 2 days ago
Ok, I am missing something on this one. I am finishing up a playfield swap on a TAF and column 3 of the switches are dead. They do nothing in the switch test, I cannot trigger them with jumpers and a Diode, and I seem to have continuity all the way through the switch circuit. So I assume U20 is dead, right?
I bought a bunch of the chips a while back and have put no less than 5 in, with none of them bringing the switch column back to life. So surely I do not have a bag full of U20's that are all dead in the exact same way, Right? What am I missing here? The MPU is a new aftermarket unit from Rottendog.
#2 2 days ago
If you have the switch wiring removed, and you can't trigger it on the connectors themselves, AND because you've tried other u20's.... look for a short or missing connection between the connector and the rest of the board.
#3 2 days ago
Yes to the above. Stop replacing the chip! First try to trigger one of the switches by shorting the appropriate two connector pins on the board with the connectors removed. If you show the correct switch closure in switch test, you have a wiring problem/break between the connector and the playfield. If no switch closure shows, something on the board or its molex pin is bad. Get a meter and start checking continuity from the pin back to the chip.
#4 2 days ago
Since the original MPU does not have U20 already in an IC socket, did you ohm out the traces to be sure no damage was done to the board once you removed it?
#5 2 days ago
Quoted from PinballManiac40:
It's a rottendog
#6 2 days ago
Barf dog
Have the original MPU available to put in?
#7 2 days ago
I have another MPU from Andrew at NVRAM.Weebly that I will toss into it next week, see if that solves the issue.
#8 2 days ago
Quoted from sbmania:
This. Could also be a poor connection in the IDC connector on the board.
$ 9.95
Macomb, MI
$ 11.00
13,000
Lake Elsinore, CA
