I have a TAF that I am converting to LED. All lights where working prior to upgrade. After switching out I now have Column 1 lighting up Column 2. Also anytime you get below Row 3 in column 1 or 2 you get the Row 7 LED on for that column. I have tested all diodes and nothing is reversed, columns are not shorted, and I am getting good pulse on all the lines. Can a bad LED bulb cause all this nonsense?
