(Topic ID: 44519)
TAF sound help
By murfe88
7 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by murfe88
#1 7 years ago
I picked up a TAF and the sound is missing speach and different sounds. The chips have been replaced on the board. The Diodes are good. I get the bong when the game boots up. The sound plays through the menu until you try to play a game then it gets all messed up. My neighbor has a TAF and we put his rom on my bad board and put it into his machine and it does the same thing so I dont think it is the rom.
Anybody have any suggestions ?
#2 7 years ago
Murfe, If you have not done so yet, I would start with re-seating the ribbon cables and make sure they are installed correctly.
Keith
#3 7 years ago
We tested the ribbon cable on my machine and we put the board in my neighbors machine which is mint with his ribbon cables and it does the same thing in both machines.
Could the RAM be bad ?
#4 7 years ago
You put the sound board in your friend's game and it does the same thing? It's not the RAM then. Reseat the non-ROM chips on the sound board (DSP, Yamaha chip, third small one below them) and see if that does anything. Also look for cracked solder joints on the ribbon header pins.
#5 7 years ago
Quoted from murfe88:
Let me see if I have the facts here.
1. What chips were replaced?
2. What diodes? With that sound board, the 47uf caps are more of an issue.
3. In test, ALL sounds play correctly.
4. What does "all messed up" mean? Do you mean that some sounds are missing?
5. Yes, you've ruled out the ROM. You've also isolated the issue to your sound board.
Answer these questions, and note correctness of my interpretation, and we'll go from there.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#6 7 years ago
We replaced the following below on the sound board. The diodes on the sound board where not replaced but tested ok. In test the sound plays correct but when you start a game there are voice call outs missing and there is background music missing.
Transistor - neg. 12v Regulator TO-220
Transistor - 12v Reg. TO-220
IC - 20 pin DIP octal edge trig flip-f
#7 7 years ago
That particular sound board has several "channels" that originate sound.
Most of them, IIRC, use 47uf caps in series. I'd start by replacing those caps.
#8 7 years ago
Thanks I will start replacing the 47uf caps.
#10 7 years ago
Awesome thank you
$ 54.00
Loop Combo Pinball
$ 12.00
$ 39.99
Lee's Parts
