(Topic ID: 247174)
TAF: right flipper locked on
By Brijam
  • 28 posts
  • 8 Pinsiders participating
  • Latest reply 4 years ago by Brijam
#1 4 years ago
Discovered the right flipper was locked on my TAF (for a long, long time). The fliptronics I board was pretty scorched. Replaced the coil as it had slightly melted, put a rottendog fliptronics board in, the flipper locks on again. No fuse blown. So.... CPU board has a blown transistor?
#3 4 years ago
Does it power up when you turn the game on ? Fliptronics board issue.
Does it lock on when you start a game ? Flipper button switch issue ( shorted ) or LM339 on fliptronics boards.
#4 4 years ago
Quoted from LTG:
Yes, it locks on when the game is turned on. So I guess I have two bad fliptronics boards
#5 4 years ago
Quoted from Brijam:
And bad coil, bad diodes, a reversed diode, wired wrong, something like these causing it.
#6 4 years ago
Quoted from LTG:
I replaced the coil, diodes looked oriented properly.
#7 4 years ago
So... new coil, this time a brand new fliptronics board, it still locks on when powering up.
#8 4 years ago
Quoted from Brijam:
Coil wired right ?
Something took out the new high power transistor - you can check if it's shorted.
#9 4 years ago
Mosfet Transistor is the issue here. Ck your MPU board.
#10 4 years ago
Quoted from Skyemont:
You thinking of the right game here ?
#11 4 years ago
Quoted from LTG:
Coil wired right ?
So check the high power transistor on the fliptronics board if it's shorted?
#12 4 years ago
Quoted from Brijam:
Yes. If it went out right away. You have something else out in the game going on causing this. Coil wired wrong, diodes on backwards on the coil, bad diode, a short to wiring or to coil lugs, bad coil. Even if parts are new. Crap happens.
#13 4 years ago
Quoted from LTG:
Ok, so to confirm there is 0% chance of a problem at the MPU or power driver board. It's either in the wiring, coil or diodes.
The symptom is that the right flipper locks on immediately when the game is powered on, turning off the power drops the flipper.
#14 4 years ago
Quoted from Brijam:
Only if it blew the transistor again. Something is blowing the transistor.
#15 4 years ago
Quoted from Brijam:
You have direct power going to that flipper. Did u replace the coil? If so, did it come preinstalled with diodes or did u add them?
#16 4 years ago
Yes, I replaced the coil; it was preinstalled with diodes. I checked that the they were in the same direction, but didn't unsolder them to test or anything.
#17 4 years ago
Ok I'm baffled.
I had previously replaced the scorched fliptronics board and a suspect coil with a new rottendog and a new coil. When that didn't work, I put a /second/ new rottendog in.
Then I put in a second brand new coil and then a brand new rottendog power driver board in. I double checked the wiring at the coil. Fuses are good.
When I turn on the game the flipper did /not/ lock on. But I started a game and got no power on the flippers. All other solenoids tested.
While the power was on (but a game wasn't started), I tried to move the right flipper with my fingers and /then/ the flipper locked on. Powered it off, then it went down.
What the heck is going on???
#19 4 years ago
Quoted from Brijam:
When J806 is pulled from the fliptronic board, does it no longer lock when R.Flipper is moved up manually ?
#20 4 years ago
Quoted from zaza:
Do you mean 906? I tried unplugging 906 and it didn’t lock on, but when I plugged 906 back in, it still wouldn’t lock on.
Neither flipper works now. I’m mystified.
#21 4 years ago
Perhaps if you could post a clear picture of the flipper coil mech including EOS it may be helpful
#22 4 years ago
Quoted from Mageek:
Mageek here you go.
IMG_3673 (resized).JPGIMG_3673 (resized).JPGIMG_3674 (resized).JPGIMG_3674 (resized).JPG
#23 4 years ago
Quoted from Brijam:
Mageek here you go.[quoted image][quoted image]
The EOS switch is needing adjustment. The long blade needs to be straight. The bottom short one should also be straight. Grab the plunger (not the link) and pull it down. Right before it bottoms out the EOS switches should touch. Adjust the BOTTOM leaf of the switch if needed.
#24 4 years ago
It almost looks like your solder tabs are touching.
#25 4 years ago
I went ahead and adjusted the EOS, even though it was working fine before (touching just as the flipper was at full extension), but that made no difference.
I tried messing around more and found out a couple of things:
1) physically holding the lower right flipper up locks it on (buttons do not trigger any flippers)
2) physically holding the upper left flipper up locks it on, but it's more of a stuttering lock
3) physically holding the lower left flipper causes the upper right flipper to trigger when the lower left flipper triggers the EOS
#26 4 years ago
Quoted from Brijam:
Bump
#27 4 years ago
Quoted from Brijam:
Looks good other than it's hard to tell what that schmutz is below the org / grn wire on the coil jacket, also roll pin on the plunger should be pressed in.
Have you replaced the ribbon cables? My TAF had a locked on flipper coil and my TZ had a locked on flasher both caused by bad ribbon cables.
#28 4 years ago
Quoted from Mageek:
Turns out J805 and J806 were reversed on the fliptronics board, and I think J805 was off by one pin as well.
$ 24.00
Various Novelties
Pinball Photos LLC
$ 24.00
Various Novelties
Pinball Photos LLC
$ 29.95
$ 41.99
Lee's Parts
$ 329.99
11,000 (OBO)
Hanford, CA
$ 28.99
Lee's Parts
Pinball Photos LLC
$ 119.00
Loop Combo Pinball
$ 19.99
Mitchell Lighting
$ 320.00
Avid Creations Wireforms
$ 9.95
$ 140.00
pinballmod
Twisted Tokens
20,000 (OBO)
Oakdale, CA
$ 145.00
Twisted Tokens
26,000 (OBO)
Auckland, NZ
$ 180.00
$ 84.99
GMods
$ 95.00
Twisted Tokens
$ 27.99
Rubber/Silicone
Comet Pinball
$ 29.00
Pinball Photos LLC
$ 55.00
Twisted Tokens
$ 25.99
Lee's Parts
$ 1,159.00
8,500
Vancouver, BC
This page was printed from https://pinside.com/pinball/forum/topic/taf-right-flipper-locked-on and we tried optimising it for printing. Some page elements may have been deliberately hidden.
